250 Rear Seal Leak....HELP
发表于 2021-8-31 22:14:13 | 显示全部楼层 |阅读模式
ok so ive had my machine a while, its a 90's 250, yesterday after I shut it down I noticed some oil below the point where the generator and engine connect. I'm assuming this is the rear oil seal, it doesn't leak a lot of after about an hours its got a few drops. How expensive is it to repair? Are there any alterntive "quick fixes"?
Reply:i had luck with "blue star" rear  main oil sealer, it can be used on rubber oil seal not on the roped seal on sa 200 good luck
Reply:where can I get it
Reply:auto parts store
GMT+8, 2026-1-2 05:03 , Processed in 0.115261 second(s), 18 queries .
