How to degrease the inside of square tubing?
发表于 2021-8-31 22:14:11 | 显示全部楼层 |阅读模式
I need to clean the inside of 12 joints of 1 1/2" square tubing well enough that it will rust.  I also want the outside to rust, so degreasing both at the same time would be nice.Before you ask, the rust makes my sealant adhere better for two reasons:  1) rust indicates the surface is/was oil free and 2) creates a rough surface that helps with mechanical grip.I use a two-part polyurea sealant (same general material as a sprayed-on bedliner) to prime raw steel whenever possible.  I want to coat the inside of the tube to prevent/minimize rusting from the inside out.I could probably rig up a pump and circulate a detergent through each joint...Any thoughts??
Reply:Steam. I have a Delco pressure washer that will also produce wet steam, works wonders for cleaning that oily tubing on the outside. Should work on the inside too.
Reply:I'm not set up for steam - in any way, shape, or form.  I wish I was   A hot pressure washer is about a hundred times more effective than cold, and (I suspect) steam is that much more effective than hot water.
Reply:Not to sidetrack, but I'm curious what the product is that you're using? And how you're applying it? Sent from my SM-G900V using Tapatalk
Reply:Full a bucket with Super Clean or another degreaser. If you only need to clean a little ways into the tube, grab a bottle brush and swab 'er good. If you need to do a whole length, soak a rag real good in the degreaser, stuff it in the tube and shove it down. Rinse with water after.
Reply:take it to the car washThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:super clean
Reply:Originally Posted by JustmeNot to sidetrack, but I'm curious what the product is that you're using? And how you're applying it? Sent from my SM-G900V using Tapatalk
Reply:Thanks! Sent from my SM-G900V using Tapatalk
Reply:Soak in vinegar.  It's a mild acid. Rinse with water and wait, it'll rust.Eventual master of the obvious, practitioner of "stream of consciousness fabrication".  P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
GMT+8, 2026-1-2 05:02 , Processed in 0.099600 second(s), 18 queries .
