Keeping the rod in the gas stream?
发表于 2021-8-31 22:14:07 | 显示全部楼层 |阅读模式
Seems like it would take a big cup to keep the soot off the end of the filler rod what do you guys do about it?
Reply:No, it doesn't.  There must be something off in your system as a whole, as even myself as a newbie can keep filler rod ends clean with normal size cups.  Perhaps what you're describing/thinking is "soot" isn't really soot, but you think it is.  I find it difficult to believe this even merits a discussion .  Can you please post an actual picture of your sooted filler rod? 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Show a pic bud that will help with helping you.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:If you are getting soot when doingTIG, there is something that is causing it.   The only times I've seen soot when welding aluminum is:a) When I've used the wrong gas (c75 leaves sooty marks)b) When I forgot to clean the sticker from the back of the bar of aluminumc) When I've used DC instead of AC.I do keep the end of the filler close to the cup but not so close that it melts.  Dan----------------------------Measure twice.  Weld once.  Grind to size.MIG:  Lincoln SP100 TIG/STICK:  AHP Alphatig 200X
Reply:1/16 filler rod
Reply:Keep rod in gas stream during weld, and during post flow. If you welds stays clean, so will your rod. Oil is not causing that.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by motolife3131/16 filler rod
Reply:I know it's not oil. Like I said I wipe them down first. The mark is about same size as cup I use.
Reply:What size cup, stickout, and what gas flow?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Are you using a foot pedal or scratch start?
Reply:Originally Posted by shovelonWhat size cup, stickout, and what gas flow?
Reply:Originally Posted by TimmyTIGAre you using a foot pedal or scratch start?
GMT+8, 2026-1-2 06:55 , Processed in 0.107115 second(s), 18 queries .
