Gear Head Art
发表于 2021-8-31 22:14:04 | 显示全部楼层 |阅读模式
Made this today. It is a crankshaft mounted to a cylinder head and has an air filter as the lamp shade Share with us what you have made.Sent from my iPhone using Tapatalk
Reply:Show your steps. The pic is very dark.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:More pics would be great. Are the head and crank from an older motorcycle?GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Sorry about the poor picture. I used old Tecumseh parts from an 8hp I took apart a while ago. I started by drilling the hole for the spark plug in the head big enough to accept the flywheel side of the crankshaft. On the bottom side of the head I used the nut to lock the crankshaft to the head.  Then I drilled a hole for the wire to run inside the crankshaft the entire way until it got to the bottom.  I welded a nut with the same threads as the lamp kit can with in the top of the crankshaft (PTO side).  The lamp kit came from Menards for about 6 dollars.  The threads are 1/8 IP which stands for iron pipe.Sent from my iPhone using TapatalkLast edited by Br4denJ; 12-27-2014 at 05:49 PM.
Reply:Nice man. Looks like a 2 smoke head. That looks like a heavy crank for 8 hpLast edited by motolife313; 12-27-2014 at 06:20 PM.
Reply:And are those hand cuffs I think I see?
Reply:Originally Posted by motolife313And are those hand cuffs I think I see?
GMT+8, 2026-1-2 06:55 , Processed in 0.076523 second(s), 18 queries .
