Anybody know how to put a roll in 14ga tread plate without expensive equipment?
发表于 2021-8-31 22:14:02 | 显示全部楼层 |阅读模式
I am looking to put a three inch radius in fourteen gauge tread plate. I looking for a 6" half pipe shape. Anyone know how or any ideas?
Reply:If you look on YouTube there's a guy named chucke2009 that made a bender like maybe what you need that he build cheap. Or maybe tack it to a 6 inch pipe and heat it with a torch then bend it overLast edited by motolife313; 12-27-2014 at 01:15 PM.
Reply:Originally Posted by motolife313there's a guy named chucke2009...
Reply:Take a 6" piece of pipe and cut it in half then clean the sharp edges off of it so it don't scrape anything up. Tack a half to a piece of plate and now you have a die. Take your plate and lay it over the die and either press it with a slightly smaller piece of pipe, beat it easily with a smaller piece of pipe, and if you really have to go complete poor boy put everything on the floor and hang on to something and stand on everything and use your body weight to press it in. Done!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Am I reading it correctly that it is a 6" long piece of 6" 'halfpipe?'  How accurate a bend, and in the final part, do other features restrain the shape, or is it completely freestanding?  If other features hold the shape, you don't need to be as accurate - you can always pull the final bit with clamps, then weld it together.  I'd be more inclined to bend that around the outside of something, rather than the inside.  I'd start with a piece of 4" pipe, as there will be a bit of springback - tack the end of your 14 gauge to it, then tack a piece of bar or tube to the other end, for a long handle.  Now, walk around it.Last edited by bassboy1; 12-27-2014 at 02:18 PM.Who is John Galt?
Reply:Take it to a shop, and spend $35.  If you want it done right."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Can you get a hold of a piece of schedule 5 or schedule 10,  6" diameter pipe and just cut to length and then slit it? Or do you have a critical tolerance"Rolling those diameters is a pain in the butt. If I had to make a bunch of them I would probably setup a male and female die for the press and hit it a couple times in different spots, to get a nice curve to it.                       Sincerely,                            William McCormick
Reply:for under $100 here localy you can get it rolled.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I just realized he needed diamond plate, so they would have to be rolled or pressed. You really cannot roll a half round very nicely on any power roller I know of. No one wants to roll diamond plate, on their roller. It leaves marks sometimes. You can press them though. You hit them a couple times starting at each end and finish in the middle.                      Sincerely,                            William McCormick
Reply:you have to bump the first and last several inches in a brake to get the radius right before you roll itVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I used a comealong to bend these fenders. 3/16" I'm sure if you get creative you could do the same
Reply:Can you just weld a 6" half pipe to the diamond plate , or does the rolled part have to be diamond plate also.
Reply:Originally Posted by sbchp355I used a comealong to bend these fenders. 3/16" I'm sure if you get creative you could do the same
GMT+8, 2026-1-2 06:55 , Processed in 0.149464 second(s), 18 queries .
