How hot is to hot.
发表于 2021-8-31 22:14:02 | 显示全部楼层 |阅读模式
I have been doing some build up on ripper shanks.the shank was originally 3/4" thick now worn down to about 3/8" thick. I am using 5/32 lincoln Excalibur 7018 on my new to me sa 200 fifth gear ? ( left dial high setting) right dial 10 or 15  I got this fron the thread on how to set a sa 200 welds good but seems to get a lot of heat buildup in the part. On the lincoln dc 400 5/32 7018 lincoln Excalibur rod set at just over #3 on amps dial and 3 on arc force welds good. Only running about 4-6 rods then letting cool down. When finished I put hard surface in a x pattern. So how hot would you let it get before cooling down? Would there be better rods or wire to use ? On the sa 200 are the settings even close? Now some Picts.[ATTACH=CONFIG]950671  Attached ImagesLast edited by Weld one; 12-26-2014 at 09:34 PM.
Reply:Those are not the settings I am using . The picture was taken at a different time.
Reply:I'd probably be 3rd range and about 80 on the fine adjustment for that rod.For 7018, I like to use a range that allows the fine adjustment in the upper range.I'm no engine drive pro, but that's what I like.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveI'd probably be 3rd range and about 80 on the fine adjustment for that rod.For 7018, I like to use a range that allows the fine adjustment in the upper range.I'm no engine drive pro, but that's what I like.
Reply:I use 3rd gear and around 70-80 as well.Welding 3/4" thick grader blade in the flat and overhead position.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Now the important thing...Why Green?Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by dumb as a stumpNow the important thing...Why Green?
Reply:There are specific hardfacing rods. If you alternated sides left then right, I don't think getting too hot would be much of an issueTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:150-175amps for 5/32.If the metal adjacent to the weld is starting to turn a deep blue, it's getting a bit hot,, and needs a cigarette break before continuing.(and what am I doing up at this Ungodly Hour????  Sudafed  Crap doesn't let you sleep )"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by 12V71Nobody in their right mind would steal it?
Reply:Originally Posted by BistineauMost people in their right mind don't steal anyway. What about all those ones in their wrong mind? What color do you suggest for those folks to prevent them from stealing it?
Reply:Originally Posted by MinnesotaDavePaint it like a miller bobcat?
Reply:If the machine welds how you like it go with it. Have to ask why not use 3/16 7018?? Your work looks good. By the way nice little ripper It's 4 inch thick. I cut out the worn down part and welded in a new piece. It was worn to about 1 inch   Your
Reply:That is a nice ripper. 5/32 is the largest they had without ordering some.
Reply:Hahaha!Paint it like a miller.I love that.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Hahaha!Paint it like a miller.I love that.
GMT+8, 2026-1-2 08:30 , Processed in 0.075266 second(s), 18 queries .
