Need help to ID a part
发表于 2021-8-31 22:14:00 | 显示全部楼层 |阅读模式
I wasn't for sure where to post this.I am working on a project with round steel telescopic tubing. I am needing some parts for the project, but I am not sure what the part is called and where you can find it. I am having no luck. I am needing the plastic pieces that you see on hand pole saws or like tripods for video cameras. The piece that goes in between the tubing that you can twist to tighten or loosen to either extend or retract the telescopic tubing. Some of them twist and some just latch tight. Here are some pictures of what I am looking for. If anybody knows what there called or where to buy them let me know. Thanks, Attached Images
Reply:Not much help, but they work the same as machine collets. I'm guessing that they are proprietary to the manufacturer or at least machined/molded to manufacturer's specifications. Never seen them for sale separately. With a lathe they would be no problem to produce...without, not so much. Hope I'm wrong.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Try telescopic pole locking mechanisms. In a google search.
Reply:This may give you enough information to find what you are looking for.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:http://dragonplate.com/ecart/search....&Submit=Search"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Ferrules would be another word to describe them.
Reply:I believe those are called, "whatchamacallits"."I believe those are known as "whatchamacallits".  Seriously I hope someone can help you, I need something like that for my extendable outrigger arms that hold small pontoons for my fishing kayak.Some kind of Big Blue constant current welding machineAnother smaller yet, Blue machine (it's got wire in it)
GMT+8, 2026-1-2 08:30 , Processed in 0.102369 second(s), 18 queries .
