Miller 140 STR
发表于 2021-8-31 22:13:51 | 显示全部楼层 |阅读模式
Hello,I bought a used Miller 140 STR,Im looking for a 6 pin remote for this unit.Also looking for a shoulder strap.Used is fine as long as there in desent condition.Thanks in advance.
Reply:I recommend you buy a 14 pin pedal, and use the adapter cord. These pedals are more commonly available used, and will work with most miller tig welders you may upgrade to in the future (well, not the really old ones, they use a different style). The adapter is about $35. Google "Miller 300507 ADAPTER CORD 1 FT 6 PIN MACHINE TO 14 PIN CONTROL".JasonXMT 350 MPA Dynasty 280DXSuitcase 8RC / OptimaSpoolmatic 30AThermco Ar / C02 mixerAssorted O/A gear
Reply:Originally Posted by welder99Hello,I bought a used Miller 140 STR,Im looking for a 6 pin remote for this unit.Also looking for a shoulder strap.Used is fine as long as there in desent condition.Thanks in advance.
GMT+8, 2026-1-2 09:56 , Processed in 0.122031 second(s), 18 queries .
