查看: 2|回复: 0
Need help with high idle on Weldanpower
发表于 2021-8-31 22:13:45 | 显示全部楼层 |阅读模式
Hey ;I have a used Code 8928 Weldanpower with a 16 HP Briggs Industiral that run good with the high auto idle coming on by itself. I decdied to clean it up and noticed that I  had to replace the armature  thru bolt , missing, and a fan that was all busted up. I marked the wires carefull when I took it apart, including the two from the high idle solenoid. I had to remove the choke coil, and engine, then  loosened up the armature from the Briggs tapered shaft. Again, I marked  carefully.Took out the brush holder assembly also  Now here I am at is that the auto high idle will not work, undless, you trip the high idle switch. Before I took the machine apart, the high idle come on when you struck an arc, or put  a demand on her for juice. The AC voltage on low idel is about 70 volts, on high idle about 100 volts. So any ideas as to what in the heck is wrong would be appreicated.  . Can those two solenoid wires be crossed at all? Kinda of a brain teaser. Waht is it that senses the load anyhow? tanks
Reply:Horvik,If you don't have the unit manual, go here http://www.mylincolnelectric.com/Cat...ualsearch.aspx to download it.However, this wiring diagram may be the specific one for your machine and differs slightly from the one in the above manual:M14240_728200990938 AM.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:You can always contact lincoln and they will send you the correct diagram for your welder, if you supply them the code number.
GMT+8, 2026-1-2 06:49 , Processed in 0.093530 second(s), 18 queries .
