ok so welder was working great two days ago, today went to run a scedule 40 8in and the stupid thing closed up, usually i run higher fine adjustment in 1st gear because i usually have a decent keyhole and dont need any "dig". But today i went to bump it up to 2nd gear about 35 to get more dig so i could push in the root and it would barely weld. Like it wouldnt form a puddle just melt the rod. yet it runs fine and hot in the upper fine adjustments. Would this be a ground issue with a bad connection or what?kinda pissed cuz had the best root i ever laid rockin in and then it wouldnt dig out on the closed section. it was between 2-4 on the pipe
Reply:Clean the armature and back of the rheostat Sent from my iPhone using TapatalkLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Alright...youre gonna have to walk me through how to do that...im gonna assume thats the problem since it rained yesterday and the welder is on the back of my truck with the bottom of the exciter cap is open
Reply:and what do i clean it with
Reply:and you want to be a pipeline hand.
Reply:not "want to be" already broke the cherry bubba
Reply:i kinda felt it worked the other way around. i thought the lower the fine, the more flowy, and the higher the fine- the more sparsy
Reply:Nope. Read any SA200 manual section on the dual "Shield-Arc" controls.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by 123weldi kinda felt it worked the other way around. i thought the lower the fine, the more flowy, and the higher the fine- the more sparsy
Reply:i cant read it, but i believe you. iobviously musta been wrong. somethings wrong w/ one of my machines, cuz it has hard time keeping xx10 staying lit w/ fine rheostat in lower positions. thats why i wrongly thought what i did. sorry if i accidently fooled anyone. i didn't mean to, i only lie when i need to |
