Cutting the black sut of ur tig filler rod
发表于 2021-8-31 22:13:41 | 显示全部楼层 |阅读模式
Any one snip the  half inch of the black crap of ur filler rod with dikes?  Also how about for aluminum rod? I can see the crap floating in the puddle if I don't snip it. I always wipe the rod down first with acetone. There's so much crap on them!
Reply:You're doing it wrong.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:im no aluminum guru i have tigged very little.with stainless it is good practice, but i seldom do it. ideally, the rod should never leave gas coverage when hot. occasionally mine does and that is when i will snip.some of the best welders i have seen dont go anywhere without their dikes. they snip before each weldbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Doing what wrong mike. Maybe a little elaboration would help.
Reply:That's what I'm taking about before welding again
Reply:If You typed English We might understand Your post.
Reply:Originally Posted by mcostelloIf You typed English We might understand Your post.
Reply:165 views and 1 comment. Must be all mig welders viewing
Reply:Originally Posted by motolife313165 views and 1 comment. Must be all mig welders viewing
Reply:Originally Posted by AKweldshopIf it helps you, by all means do it!!Nothing wrong or right about snipping your filler rod.Do what works for you!
Reply:I do not normally have soot on my filler rod between beads.   If I did see any contamination I would clean it off or cut off that piece.  It's quicker to snip off a piece.   I store the acetone and rags far from my welding table.Dan----------------------------Measure twice.  Weld once.  Grind to size.MIG:  Lincoln SP100 TIG/STICK:  AHP Alphatig 200X
Reply:Originally Posted by weldermikeYou're doing it wrong.
Reply:Wipe the rods with Scotchbrite works good tooTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I clean them with acetone before even welding bc they get oil on them from the factory. So do u guys hold the rod under the cup when the welder is post flowing? And is the how you get no black soot on there?
Reply:I guess no one wants to give there's secrets out
Reply:Originally Posted by motolife313I guess no one wants to give there's secrets out
Reply:Originally Posted by motolife313I clean them with acetone before even welding bc they get oil on them from the factory. So do u guys hold the rod under the cup when the welder is post flowing? And is the how you get no black soot on there?
Reply:I've never personally done this at home or in the shop.  I was working in the field repairing leaks in a tube sheet on a heat exchanger.  Wire. was 70S-6 and there was an inspector there who wanted each piece of wire wiped down with scotchbrite to remove the copper coating, and after each stop had to cut the wire back about a 1/2 inch.  Never had it happen again.
Reply:Quick guess with no pics would be a bad torch angle. Without pics if everything is on the money that would be my guess. Like said "guess".I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:How come the factory gets oil on your rods?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonHow come the factory gets oil on your rods?
Reply:Originally Posted by motolife313Wipe a filler rod down with acetone and see what u find! My lws said they get oil on them somehow
Reply:I normally don't snip unless something happens that turns the tip of the filler to crap. OR if I am working on some nuclear ****.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by shovelonChinese?I didn't buy the whole box I usually buy a couple pounds at a time. She lets me get even a 1/4 pound if I wan't she is awesome. She is the owner of a small welding shop. Not like airgas rediculas prices even tho I bought my welder from them at employe cost price
Reply:HQA and Washington Alloy. Neither have given me a problem and they are sealed 10 lb. lots.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Have u tried wiping them down tho?so if ur filler rods gets away from the cup do u stop right there and snip or just keep on motoring
Reply:I always clip my ends. Can't remember the last time I used acetone on anything. Occasionally I'll  wipe the wire with my shirt tail.
Reply:Originally Posted by TimmyTIGI always clip my ends. Can't remember the last time I used acetone on anything. Occasionally I'll  wipe the wire with my shirt tail.
Reply:Thanks for the input! What do u clean ur metal with then? Also tungsten?
Reply:I've said it so many times the filler rods are coverd in gunk. The proof is the the rage. I do it every time now and wipe it like 3 times. And there the owners anyway. Not that it really maters any way or nore does  pay. A lot of poeple like to sound like a know it all
Reply:I think what you might be seeing has to do with the copper. Even clean copper if you rub it for awhile you will get a blackish residue off of it.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Well I get the same with 308 and 5356. And one swipe shows up
Reply:Originally Posted by motolife313Well I get the same with 308 and 5356. And one swipe shows up
Reply:If I look at the ends of my used copper coated 70S filler I see that the copper has burned away.   It does not appear to be soot.  It does not wipe away with a wet cloth.  Dan----------------------------Measure twice.  Weld once.  Grind to size.MIG:  Lincoln SP100 TIG/STICK:  AHP Alphatig 200X
Reply:Originally Posted by shovelonYou are out of your mind.
Reply:Originally Posted by dbstooIf I look at the ends of my used copper coated 70S filler I see that the copper has burned away.   It does not appear to be soot.  It does not wipe away with a wet cloth.  Dan
Reply:Sounds like a few people do
Reply:If you work with aluminum you need to alcohol it off then sand it. If you sand it then alcohol it does no good. If you sand stuff with trash and dont wipe it off first it bed the grit and garbage into the metal. I don't snip my aluminum wire. If your seeing crap in the puddle when welding aluminum clean the aluminum, wire brush it with a stainless brush. Always snipe the ends off carbon, stainless, and titanium.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:You mean just the end of the rod where that white crap is or the whole rod. And do u you scotch bright? If so wich one? Is alcohol better then acetone on aluminum filler rod?
Reply:Originally Posted by motolife313I'm wondering what some others do aswell. And if its nessesary with aluminum?
Reply:Originally Posted by motolife313Jodie at welding tips and tricks must be to bc he does the same thing
Reply:Originally Posted by motolife313I've said it so many times the filler rods are coverd in gunk. The proof is the the rage. I do it every time now and wipe it like 3 times. And there the owners anyway. Not that it really maters any way or nore does  pay. A lot of poeple like to sound like a know it all
Reply:Don't get ur panties in a wod buddie. So all the good welders that clip there rods on here are jacking them up to? And I was referring to Jodie wiping his rods and he does so there you go bro question answered. And u never answered my question about you finding gunk on ur rods?Last edited by motolife313; 12-01-2014 at 12:27 AM.
Reply:Originally Posted by motolife313Don't get ur panties in a wod buddie. So all the good welders that clip there rods on here are jacking them up to?
Reply:Originally Posted by motolife313Don't get ur panties in a wod buddie. So all the good welders that clip there rods on here are jacking them up to? And I was referring to Jodie wiping his rods and he does so there you go bro question answered. And u never answered my question about you finding gunk on ur rods?
GMT+8, 2026-1-2 06:49 , Processed in 0.117623 second(s), 18 queries .
