how to pull hours out of dynasty 700
发表于 2021-8-31 22:13:39 | 显示全部楼层 |阅读模式
can someone tell me the procedure to get the number of hours on a machine and are those hours arc hours or as soon as the switch comes on hours
Reply:Originally Posted by tnc110can someone tell me the procedure to get the number of hours on a machine and are those hours arc hours or as soon as the switch comes on hours
Reply:Perfect.   Thank you.
Reply:Too hard to look in the owners manual I guess.
Reply:Originally Posted by mikecwikToo hard to look in the owners manual I guess.
Reply:It's actually much easier as a 2 person operation. Push the wrong buttons while powering up can be a bummer. Guilty as charged. Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:It is arc time. Machine also keeps track of strikes.
Reply:Originally Posted by soutthpawShovelon would be the guy to ask as he has one
Reply:Originally Posted by shovelonMy 700 has 860 hours.Julie's 350 has over 2000 hours. Hmmm.
Reply:Originally Posted by soutthpawGuess we know who is doing all the work around there.
Reply:rtfm.Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by shovelonFunny guy DJ!  Guess I should shave my beard and wear a bra.
Reply:When you are going to look at a used machine and you don't know if the owner has the manual or if the info is even in the manual, and you can't seem to find the answer to your question on the Web then you post the question on a welding forum so those with more knowledge than you can help. ....   Originally Posted by mikecwikToo hard to look in the owners manual I guess.
GMT+8, 2026-1-2 06:49 , Processed in 0.071237 second(s), 18 queries .
