Heat input. Sorry Jodie :)
发表于 2021-8-31 22:13:36 | 显示全部楼层 |阅读模式
1/8 lap joints that are 3 1/4 long. 1 ran at 160 amps floored with less overall heat input and the other ran at 90 amps floored that took much longer and more overall heat input. I should have put the heat gun on them both right after but just now thought of that lol.the one welded  At 90 amps it started to flow good the last 1/4 of the piece. Ran a red 3/32 tungsten with #5 cup at 10 cfh and 1/16 70s2. I plan on doing another one maybe at 180 amps.
Reply:Isn't this exactly what Jodie did a video on?
Reply:Yep, same results too Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nicely done moto!!Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Thanks AK!
Reply:motolife313For practice - looks great - in developing your hand.As an engineered weld joint - it flunks all criteria. Opus
Reply:Depends what your building
Reply:Seems strong to me
Reply:Originally Posted by OPUS FERROmotolife313For practice - looks great - in developing your hand.As an engineered weld joint - it flunks all criteria. Opus
Reply:AKweldshop  -  "Care to elaborate, genius?" Certainly:Read the entire thread . . .http://weldingweb.com/vbb/showthread.php...cking-with-TIGSame issues - inverted - but as inept.Ak -I would be more concerned about Lead-Paint;than critiquing welds beyond your ability.Opus.Last edited by OPUS FERRO; 01-04-2015 at 03:34 AM.Reason: es/isn't/is'es
Reply:the one on the far left was welded at 80 amps. And I tried welding another at 180 amps. I was amazed how big the puddle was and was kinda whatching it instead of moving and adding filler. The heat zone was a tad bigger on the one welded at 180 over the one welded at 160. The heat gun read about half the temp as the one welded at 180 then the one at 80 amps.
Reply:YUP that's what I was taught crank the amps and move faster  put less heat into the work/
Reply:Well?I certainly am at AWE!I would have not thought that the HAZ would have been like that.It does make sense that you would have to heat more material WAITING for the Welding area to reach bonding temps at lower amps.Thank You!
GMT+8, 2026-1-2 06:56 , Processed in 0.068966 second(s), 18 queries .
