Rock Buggy
发表于 2021-8-31 22:13:36 | 显示全部楼层 |阅读模式
Buddy brought his buggy over for me to build a fuel cell and a set of headers for it.... Attached Images
Reply:That thing looks great.  How about some more details?ThanksTodd
Reply:I was a bit confused by the pvc shocks but I get it now. Buggy looks great. I got a friend that's getting into building those. I've seen a lot of junk rolling around but this one is top notch.Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:Are you gona go with a long header length?what motor is in it?
Reply:That thing looks cool.  Top notch!
Reply:It's gonna be a LS based power plant TH400 transmission..  Some kinda bad *** transfer case.... On 42" tires...
Reply:Got the passenger side mocked up... Attached Images
Reply:I think you will need more collector length sense It will probably be  a low rpm motor most of the time. What header length did u use and collector size
Reply:How will you weld that collector to those runners all the way around?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:motolife313  the tubes are around 20" 1-3/4"  3" collectors... I'm just doing it the way the owner wants it...    I agree the tubes could be a little longer but I believe it will be fine.. He's not trying to set the world on fire....  Gamble the collectors are top secret!   No,, you put a Throwing star shape filler piece where the tubes all come together weld it in and then continue the weld at the end of the points and continue them around to the outside of the tubes up to where the top of the collector will go and then when you weld the collector on it will be all sealed
Reply:Thats good for like 8 to 12000 rpm range. Customer gets what customer wants I guess. Those are some really nice bends. U could have used 1 5/8 with bends that nice
Reply:Originally Posted by motolife313I think you will need more collector length sense It will probably be  a low rpm motor most of the time. What header length did u use and collector size
Reply:I was thinking of Rock crawler. My bad
Reply:Headers are finito! Attached Images
Reply:Great job! Are the stainless or mild steel? How about a close up shot!? Did you back purge?
Reply:Thanks.    Motolife. They are mild steel so I didn't back purge them... He is going the have them coated.
Reply:Where did you find such big radius bends? Those look like 6 in radius?
Reply:Or did you bend them yourself?
Reply:Originally Posted by motolife313Or did you bend them yourself?
Reply:There right down the street from me. They got alot of aluminum stuff to.
Reply:Originally Posted by motolife313There right down the street from me. They got alot of aluminum stuff to.
Reply:Wow that is nice. What motor and heads is that?what time you run?
Reply:motolife  sent you a pm.. did you get it?
Reply:It's called (pipemax) it's about 75 dollars and I think you get about 2 or 4 keys. The guy who designed it is a expert head porter and engine builder. Larry muaex is his name. You can learn more about him at speedtalk.com there is alot more then header specs when you buy it. It's about harmonic wave timing.  Well worth buying if you port heads and make intake and headers!!!! Darin Morgan uses it to over at reher Morrison. They sell 80000$ crate motorsOriginally Posted by motolife313Wow that is nice. What motor and heads is that?what time you run?
Reply:Awesome headers! Nice work.
GMT+8, 2026-1-2 08:31 , Processed in 0.072640 second(s), 18 queries .
