查看: 2|回复: 0
Grass hopper ground clamp
发表于 2021-8-31 22:13:36 | 显示全部楼层 |阅读模式
Anyone ever make one of these before?
Reply:I had to google it to even see what it was. I have never seen one in use and I cannot picture what it could be used for instead of a regular ground clamp. What are they meant for?Mikel
Reply:pipeline welding  clifton
Reply:When welding pipe there's no place to attach a squeeze type ground clamp.  You can sit a grasshopper on your joint.  A lot of folks use a T300 stinger to clamp to the grasshopper instead of a normal ground clamp.
Reply:Here's the link for the grasshopper pipeliner posted. There are a few more photos.http://www.custombuilttools.com/welding.html
GMT+8, 2026-1-2 06:49 , Processed in 0.071272 second(s), 18 queries .
