king size Bed frame
发表于 2021-8-31 22:13:35 | 显示全部楼层 |阅读模式
Heres a bed frame i made for my new place. the head board and foot board are made out of 4x4 tubing and the side rails are made of 2x2 and i recessed 2 boxes on both sides of the head board for receptacles Attached Images
Reply:Great idea for the built in plugs. They are never close enough for a phone charger.Lincoln Pro Mig 180Lincoln Pro Core 125Hypertherm 30xpPorter Cable Drill PressAcra 7x12 bandsaw48" sheet metal brakeCrap load of other tools, working on metal now.
Reply:I then had it powder coated with a textured powder coat and i will paint or stain the wood on the head board later. once the wife decides the color lol Attached Images
Reply:Nice and sturdy.Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by KMcCurdyGreat idea for the built in plugs. They are never close enough for a phone charger.
Reply:chevyvortechUnresolved fixtures - they should be as 'Zoomie' - as the electrical outlet. Opus.Last edited by OPUS FERRO; 01-08-2015 at 01:38 AM.Reason: Reveal/Fit/Finish
Reply:what do you mean by fixtures cause the outlets are "fixtures". and im not really sure what "zoomie" is Originally Posted by OPUS FERROchevyvortechUgly fixtures - they should be as 'Zoomie' - as the electrical outlet. Opus.
Reply:chevyvortech'Ugly or unresolved fixtures' means: these components are not up to standard with your over-all work.Zoomie/Zoomy - [not Poopie/Poopy].Zoomie means - the design, the fixtures, and the welds, are all in balance - and should be as clean as the E-box.Your design is good - the fixtures are weak - and everyone's welds can always be better.The reveal of your work should be as clean as the E-box.Opus.Last edited by OPUS FERRO; 01-08-2015 at 03:31 AM.Reason: P ain't Z
Reply:That's a pretty cool frame! Nice work.
Reply:4 and 2" square tubing? are you sure it's going to be sturdy enough? in year's gone by i would've liked something like that for lights out acrobatics. nice work.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docwelder4 and 2" square tubing? are you sure it's going to be sturdy enough? in year's gone by i would've liked something like that for lights out acrobatics. nice work.
Reply:Nice job.  I like the outlets. Cool idea.
Reply:That thing is awesome! Good proportions with the size of the square tubing. The fit and finish appear to be top notch. Just how heavy is it going to be to move? It doesn't look light.HTP Invertig 221Hypertherm Powermax30 XPPlus other stuff
Reply:I all ways wanted to make a new iron bed ,just never got around to it .The addition of  an electric wench would work well with the D rings on the ceiling and the material vibrator under the matress. !!!
Reply:I prefer canopy-style beds with a built-in trapeze."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by gxbxcThe addition of  an electric wench would work well with the D rings on the ceiling and the material vibrator under the matress. !!!
Reply:Really nice! I've been thinking of making one for some time now.  I was afraid that 4" tubing would be too big to look good but I was wrong.  What wall thickness did you use?GravelThe difference between theory and practice is that in theory there is no difference.
Reply:I have a king size bed and my 2 dogs still find the need to try and squeeze me off the side....lolOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Originally Posted by 7A749The four point tie down locations are just an added bonus
Reply:Originally Posted by OldendumYou into twins or what?
Reply:Originally Posted by SquirmyPugOversize loads require additional straps.
Reply:add more support for this one..lolOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Originally Posted by OPUS FERROchevyvortech'Ugly or unresolved fixtures' means: these components are not up to standard with your over-all work.Zoomie/Zoomy - [not Poopie/Poopy].Zoomie means - the design, the fixtures, and the welds, are all in balance - and should be as clean as the E-box.Your design is good - the fixtures are weak - and everyone's welds can always be better.The reveal of your work should be as clean as the E-box.Opus.
Reply:That is just wrong roadkill..  MODERATORS !!millermatic 130XPharbour freight 180 amp mig with added caps.hobart stickmate ac/dcpowerarc 200
Reply:Originally Posted by weldinghomerThat is just wrong roadkill..  MODERATORS !!Originally Posted by gxbxcI all ways wanted to make a new iron bed ,just never got around to it .The addition of  an electric wench would work well with the D rings on the ceiling and the material vibrator under the matress. !!!
Reply:Hilarious!!!!!  Everlast PowerArc 300
Reply:ok this is more my style...Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Style? ...or pipedreamWelding/Fab Pics: www.UtahWeld.com
Reply:for post bed means flying gamahuch!!!!!!!!( if any one remembers the GREASE MAN)
Reply:Thanks I think it turned out pretty good. It was all 1/8 wall. I would have gone thinner but it wasn't available at the time. 5" or 6" would have been cool to but it's heavy enough as it is lol Originally Posted by GravelReally nice! I've been thinking of making one for some time now.  I was afraid that 4" tubing would be too big to look good but I was wrong.  What wall thickness did you use?
Reply:Originally Posted by 7A749A man after my own heart
Reply:I think your father in law was wondering more of what would be going on under the mirror...LOLOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Originally Posted by Mikel_24I got to say I am somewhat dirty myself!It is a matter of compromises... it might interfere with other elements you might need to install in the bedroom. Such as a bed size mirror stuck in the ceiling!Yes I do have one. No, I didn't post it before because it was not welding related. And the best of all is that I built and installed everything else but... my father in law supplied and glued the mirror!And since you guys won't probably believe me...Wooden structureInstallation in progressMy Dad (with glasses) and my cousin helping out supporting the structure. I am the ugly guy with the white shirt looking funny (to say the least)So as not to ask them to stay put for say, 20 minutes, we supported the wooden structure using a masonry tool I borrowed from a friend. It is spring loaded. We used six of them if I recall correctly. I am installing one in this picture.Structure installed, as well as the indirect ligthing.Mirror glued in place and waiting for the product to cure. My father in law didn't want it to fall on us (probably worried about her daugther mostly) and used a high strength mirror glue. Like a full tube or so.Test picture (somewhat). This reminds me I still need to remove the piece of masking tape you see on the ceiling! Mikel
Reply:i'm not even going to ask what those implements on the nightstand are.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by chevyvortechI then had it powder coated with a textured powder coat and i will paint or stain the wood on the head board later. once the wife decides the color lol
Reply:There's a piece of 2x2 going across the center with a foot on it but the foot isn't really needed and the 3/4 plywood is supported around the perimeter with 6" pieces of 1x1 square tubing Originally Posted by BigteeWhat did you use for supports across the frame?
GMT+8, 2026-1-2 09:58 , Processed in 0.082415 second(s), 18 queries .
