spool gun for lincoln sp250
发表于 2021-8-31 22:13:33 | 显示全部楼层 |阅读模式
couldn't find the lincoln interface kit,but did find this gun on ebay-- item # 271046701152 .ships from the uk for about $220.00 . requires a variable dc power supply to control wire speed. for that price,i figured it was worth trying. anyone have any luck adding a spool gun without the lincoln control package ?miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:Originally Posted by boatbuoycouldn't find the lincoln interface kit,but did find this gun on ebay-- item # 271046701152 .ships from the uk for about $220.00 . requires a variable dc power supply to control wire speed. for that price,i figured it was worth trying. anyone have any luck adding a spool gun without the lincoln control package ?
Reply:southpaw,thanks for the info.it'll probably take two weeks to get here----ordered it last night. it has the euro connector and i was planning to let it trigger the internal feed motor with no wire loaded. the spoolgun itself runs off a 0-12 volt dc power supply. i ordered one for a tattoo pen that puts out 3-18 volts . so at this point total investment is $235.00 .if it works,great.and if not,i'll put the spoolgun back on ebay.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:I recently ordered a good power supply of ebay 6amps max at 24 volts.   its a good supply with multiple voltage and connector outs.   I can get you the info if u need it. $18 I think it cost.   Ok doing it that way should work too...   so the switch on the spool gun is just activating the contactor then.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:This diagram may help.   Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:thanks,i'll update when the gun arrives.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:spoolgun from uk delivered today--that was fast. power supply from china will take a little longer.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
GMT+8, 2026-1-2 08:43 , Processed in 0.073837 second(s), 18 queries .
