spoolmatic 15a/30a
发表于 2021-8-31 22:13:33 | 显示全部楼层 |阅读模式
Just got one.It is badass.Had a 3035 spoolmate in the past..... doesn't even come close to the spoolmatic.Miller wins again.
Reply:Would be helpful if you shared what you like about it in comparison the the previous unit you had...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Two biggies.Two stage trigger.Way more power.... it will weld 1/2 plate for days.The 3035 was a hobby piece, spoolmatic is big leagues.
Reply:Hello bigshooter, which type of front end is on the spoolgun that you have now, is it similar the the first pic. that I've attached or the second one. First pic is one of the older generations and you'll note a lot more parts, second one is the "new" generation with far less parts and when you put it to work you'll generally find that the consumable life is far better as well. Great upgrade, I know you'll certainly enjoy it. Best regards, AllanEDIT: I should also note that the newer version of this front end utilizes a silicon bronze guide tube instead of the "plastic" one used in the older version, a way better, smooth feeding, guide system IMHO. Attached ImagesLast edited by aevald; 09-21-2012 at 02:59 PM.Reason: Add informationaevald
Reply:#2, the latest gen.
Reply:#2, the latest gen.Can't wait to get a bigger project.
Reply:Hello again bigshooter, what are you using to power your "new" spoolgun with? Inquiring minds want to know.........sorry I couldn't resist. Best regards, Allanaevald
Reply:Mm251
GMT+8, 2026-1-2 08:44 , Processed in 0.106714 second(s), 18 queries .
