Another 1,000 holes
发表于 2021-8-31 22:13:32 | 显示全部楼层 |阅读模式
This time I could do them in stacks of 5 tho.The top plate wanted to pull up after the vice got covered in coolant. A bit of sandpaper and spray glue fixed that.Love this new mill.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Good Gosh!   What a Job! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Sir,That my friend is alot of drilling holy chit!! Nice work
Reply:Autofeed with depth trip set?Briggs weldnpower 225/210/cvLn-25 suitcaseMillermatic 130
Reply:Originally Posted by WinmacAutofeed with depth trip set?
Reply:You mean...hopefully, you get these orders ALL of the time and you can pay someone to do it while you sit back and drink beer!  -AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:I feel your pain.
Reply:Are those for 80/20 extrusions?What mill is that?miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
GMT+8, 2026-1-2 08:43 , Processed in 0.075799 second(s), 18 queries .
