Getting the pulley off water pump??
发表于 2021-8-31 22:13:28 | 显示全部楼层 |阅读模式
Hey All,Replacing what appears to be the original water pump on my 1969 Redface. It appears to have an adjustable pulley on it and how the *heck* do you get that pulley off??skip
Reply:I have the same ? I have a 63 model,have not tried a wheel puller yet been spraying with kroll don't see any kind of keeper. Any help would be appreciated.
Reply:Originally Posted by skiprrrHey All,Replacing what appears to be the original water pump on my 1969 Redface. It appears to have an adjustable pulley on it and how the *heck* do you get that pulley off??
Reply:It should pull off just like the other kind of pulley the inner threaded hub of that pulley presses on the bearing shaft.  The Continental manuals mention the adjustable pulley but doesn't show the kind you have.  There was another two piece pulley has a slot with a bolt for adjustment too.  The L head manuals are for the F series flatheads and TM manuals for later overhead valve engines.http://www.wisconsinmotors.com/part_catalog/continentalContinental partshttp://www.montesequipment.com/
GMT+8, 2026-1-2 08:44 , Processed in 0.110481 second(s), 18 queries .
