Question on gas driven Lincoln Weldenpower
发表于 2021-8-31 22:13:28 | 显示全部楼层 |阅读模式
I have a Lincoln gas driven welder, it's a 225 amp AC/DC with 6000 watts of auxiliary power, it has a twin cylinder Onan engine on it.Welder has about 20 hours on it, and it's always been stored inside of my barn, never seen rain.I want to sell it, and was wondering what it might be worth?I bought this unit new in the 80's.Thanks.Last edited by John R; 07-28-2010 at 04:11 PM.John
Reply:What's it called? Do you have a code #, photos, anything so we can get a handle on what you have? Not enough info except to give a very rough estimate. With what you gave us an OLD welder like that is worth...maybe $300.00? Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:It's a WeldenPower 225, I put that in the subject line.John
Reply:Can't edit the above message, so I'm posting again.Model #  AC225/DC210/6Code #  9175John
Reply:The market varies from one region to another but I've seen them advertised for $5-800 in so-so condition but running/working w/o leads to twice that and more in very good condition with leads.  It would have slightly more value if it has the CV (Constant Voltage) setting to make it more suitcase MIG welding friendly.With only 20hrs and being stored inside I would imagine it's in very good shape but keep in mind it's still almost 30 years old.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:It does have CV and also CC.John
Reply:Went back out to the barn and looked again, it has CV and VV,The above post is wrong.John
Reply:Constant CURRANT=VV....same thing. Before you sell it, make SURE it runs fine.And, welds fine . It should ,with such low hours.maybe polish it up, also.[SIZE="5"Yardbird"
Reply:It looks and runs as good as the day I bought it, need to try and get some pictures to post.John
Reply:John!Depending on where you are located in Mi, I might be interested in it.It sounds like it might be about the same age as the one I have!Send me a PM!Ken.#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:KenPM sentJohn
Reply:Originally Posted by Ken DennisJohn!Depending on where you are located in Mi, I might be interested in it.It sounds like it might be about the same age as the one I have!Send me a PM!Ken.
Reply:john do you still have your weldnpower?  Iam intrested . I live in central mi, Eric
Reply:Originally Posted by kubotakidjohn do you still have your weldnpower?  Iam intrested . I live in central mi, Eric
GMT+8, 2026-1-2 08:45 , Processed in 0.114796 second(s), 18 queries .
