Pictures of Sa-250 on trailer
发表于 2021-8-31 22:13:27 | 显示全部楼层 |阅读模式
Hey,Anybody have any good pictures/ ideas of lincoln welders on a trailer with torches mounted with it. Just want something small and light to move it around. If I make a trailer, should I put springs on it or just mount the axle ridgid? Would like to mount the torches near the toung of the trailer.Thanks,
Reply:Sorry, don't have any pics of a trailer with torches.  Most machines I see are either on the back of a truck or mounted on a simple trailer with towing ring on the tongue and an axle under the machine, like mine.If I were building a trailer I would put springs under it.  These machines are relatively heavy and I would be afraid of bending the axle if I hit a big bump without some kind of suspension."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Heres mine Attached Images
Reply:cajun welder, I have a question.  Why did you mount the acetylene cylinder outside the bed of the trailer in the tongue area?  Curious as to reason.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Originally Posted by smawgmawcajun welder, I have a question.  Why did you mount the acetylene cylinder outside the bed of the trailer in the tongue area?  Curious as to reason.
Reply:Okay, makes sense, I was just wondering why.  Thanks!A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
GMT+8, 2026-1-2 08:45 , Processed in 0.111723 second(s), 18 queries .
