sa 200 reed relay
发表于 2021-8-31 22:13:26 | 显示全部楼层 |阅读模式
how much amp is this relay suppose to be ,the one that is rap by the ground welding led and is connected to the idler board, broke mine and trying to find something to replace itthanks
Reply:That reed is Lincoln part# T12012-2
Reply:Those reed switches don't carry a lot of current in the idler control circuit so one with a 1amp capacity would work if you choose not to go with an OE replacement.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks  duaneb55  , Thats what i figured,so found some 1 amps on ebay for a few bucks, and like you said, it only goes to the circut board so it cant be to much amp anywaycocomunk
GMT+8, 2026-1-2 08:44 , Processed in 0.073245 second(s), 18 queries .
