short hood code #2995
发表于 2021-8-31 22:13:26 | 显示全部楼层 |阅读模式
welder is shorted to truck bed. touch ground to bed and it arcs. checked  +  stud for short it is good. where is my short?
Reply:(+) cable where it passes thru the generator housing or (+) brush cable to housing?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Get flashlight, ohm meter and go looking for the worn or damage insulation.Resistance check from weld lead to case. Move stuff around until the short goes away.You may have to disconnect a few wires to locate the short. MAKE SURE YOU MARK WHERE THE WIRES GO. use colored tape and take pictures.The replace or repair the bad spot or terminal.
GMT+8, 2026-1-2 08:44 , Processed in 0.133069 second(s), 18 queries .
