Inverter Tig welder issue
发表于 2021-8-31 22:13:24 | 显示全部楼层 |阅读模式
Greetings all,I have a 200 amp DC Inverter Tig welder.  Following a short inside the torch handle at the trigger switch, I have no Tig functionality.  No HF start, No scratch start.  The MMA functions properly.  The fan runs but no activity when torch trigger is activated in Tig mode.  I repaired the trigger in the torch and even tried a new torch to rule that out with no success. The torch side of things seem fine.Any ideas what I should be looking for next? I've looked inside and see no obvious signs of foul play...nothing burned, scorched, melted, oozing, buldging or otherwise...Any ideas and or suggestions would be greatly appreciated.  Thank You.
Reply:What machine is it?  Most people will need to know this to help.You've asked the equivalent of "I have a car that won't run - what's wrong with it?"  Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveWhat machine is it?  Most people will need to know this to help.You've asked the equivalent of "I have a car that won't run - what's wrong with it?"
Reply:Good luck getting it fixed.
Reply:You said there was a short at the trigger switch. How did you attempt to fix it?  The switch is basically just continuity, so the wires were bare and shorted to: each other?  Another metal part? 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by OscarYou said there was a short at the trigger switch. How did you attempt to fix it?  The switch is basically just continuity, so the wires were bare and shorted to: each other?  Another metal part?
GMT+8, 2026-1-2 08:44 , Processed in 0.232555 second(s), 18 queries .
