LEVEL 1 PANIC: Please call me
发表于 2021-8-31 22:13:24 | 显示全部楼层 |阅读模式
I have a community event in the morning (March 5 2016) and I have to weld a couple things by morning.  The trigger switch failed in my Hobart 140 Handler and I cannot see how to open the gun. I have the new switch. If anyone sees this pls give me a call: Dennis 209-304-0892Many sincere thanks..Dennis PricePine Grove CA
Reply:Twist the bottom of the gun and the two halves should pop apart. Pretty sure that's how it comes apart. Check the switch with a meter and replace if need be.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Post a pic of the gun.  We can probably tell you better.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:It's the top of the gun that rotates. Here's the manual for the H10 gun that I believe is what is used on that machine.http://www.hobartwelders.com/om/0900/o943a_hob.pdfThe other gun manuals can be found on Hobart's site. Look under "H-" and the gun model. There's only like 4 models and I'm pretty sure the H-10 and H-14 guns are put together the same. Note The H-10 gun is identical I believe to the M-10 gun on my Miller, so parts like switches should interchange..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:You may find it's simply a bad wire to the gun. You can bypass that if need be if your switch tests out good. I had one of the wires break in my original M-10 gun and for temporary use I simply ran something like 22ga wire taped to the whip and spliced back in at the plug to keep using it until the correct parts arrived. A temporary switch is a bit more difficult to work up, but a small push button switch mounted some how would work in an emergency..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWIt's the top of the gun that rotates. Here's the manual for the H10 gun that I believe is what is used on that machine.http://www.hobartwelders.com/om/0900/o943a_hob.pdfThe other gun manuals can be found on Hobart's site. Look under "H-" and the gun model. There's only like 4 models and I'm pretty sure the H-10 and H-14 guns are put together the same. Note The H-10 gun is identical I believe to the M-10 gun on my Miller, so parts like switches should interchange.
Reply:you guys are fast!
Reply:They are good too!
Reply:How did you go? Make the deadline?
GMT+8, 2026-1-2 08:44 , Processed in 0.299056 second(s), 18 queries .
