The dreaded 2" sch 160 SMAW test
发表于 2021-8-31 22:13:19 | 显示全部楼层 |阅读模式
I have this test today for company I would really like to get some money from, so wish me luck. Who in the **** doesn't TIG the root. I would be gravy if I could TIG the root. I'm taking the old SA-200 with me, hope they don't get weird about it being on a trailer. I'll leave the Vantage in the truck and hand start the Continental just to confuse them.Constant Current Weldor.
Reply:Done that test for refinery work. PITA. Try it tig root, 7018 out, no grinder.Long after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:They told me I would use their welder. Ok I said. Went around back, and I had my choice between a Miller Dialarc 250 or Bobcat 250. No arc control, no practice, no joke. They are sending it out to be x-rayed for ASME. I'm glad I got enough work.Constant Current Weldor.
Reply:Originally Posted by DavidbrownThey told me I would use their welder. Ok I said. Went around back, and I had my choice between a Miller Dialarc 250 or Bobcat 250. No arc control, no practice, no joke. They are sending it out to be x-rayed for ASME. I'm glad I got enough work.
Reply:You should have no problems doing that test with either of those machines.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Should be an easy test with any of those machines. I agree that you should get a little time if they want you to use their welder. Hate to say it but for the 7018 part id take the vantage all day long.Good luck
Reply:I took the same test yesterday I was dreading it too. Usually they require tig root n hot, but not this time I had to p5. I figured out the trick with putting a nice bead in the heavy wall coupon. You can run a big gap with no land and still whip it in there nice Bc the walls can take the heat and not have to worry about it falling In.
GMT+8, 2026-1-2 12:04 , Processed in 0.102639 second(s), 18 queries .
