Syncrwave 250 arc start problems
发表于 2021-8-31 22:13:14 | 显示全部楼层 |阅读模式
So my welding class has been temp moved from Rock Springs to Dalton,Ga... They have a 5-6 ( or less ) year old Syncro 250. The machine has been sitting idle until the recent opening of the welding class. The machine worked fine the first time I tried using it a couple weeks ago and for other students in the morning classes( mostly my G/F). I attempted to use it last night and I could not get the machine to start an arc using the foot pedal. I only get H/F. I can start the arc with panel amp control and scratch/lift arc...if I set it on panel amp control I can also start with H/F using pedal but the pedal has no amp control after the arc starts( basically like a finger start button). When I switch it from amp/ output it shows 2-t for second on the digital display, is it possible to change it to 4-t( which should be pedal control  ?? ) Is the foot pedal possibly bad??   I have tested every possible setting combination... with no luck ... This is base model machine, no pulse etc...I hope this makes sense??This is base model machine, no pulse etc...Last edited by DemonSpeeder; 10-03-2012 at 06:05 PM.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Clean & adjust the tungsten high frequency pointsMiller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:How clean is the tungsten? I've seen HF start issues with contaminated tungstens at the tech school. The guy seriously fouls the tungsten, but doesn't grind all the fouling off. Usually the arc will start if they touch the tungsten to the work and mash the pedal, similar to lift start, but the arc won't always jump the gap. Usually cutting off the end and then repointing will solve the issue, that or a very heavy regrind..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:That is something I was also thinking about as well... but I can light up with H/F using the pedal... but there is no control from the pedal after...I can literally take my foot off the pedal and still weld like scratch/lift start welding . I set it exactly the way I had previously, with full control from the pedal, now all I get is H/F...Last edited by DemonSpeeder; 10-03-2012 at 07:54 PM.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:DSW, I installed a brand new #20 CK torch before attempting to use it ... I also bring my own torch parts as well and I am anal about keeping everything clean...also new argon cylinder, water cooler full of coolent... I can weld with the machine, it's that there is only H/F and it won't light the arc with pedal.Last edited by DemonSpeeder; 10-03-2012 at 07:53 PM.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:It's hard to write this without it being confusing....there are 4 buttons on top left of machine1. stick or tig2. amp = panel or remote3.output= panel or lock or remote4.start= scratch or lift or hf start or hf contFirst time using machine setting were= tig, panel amp,output remote,and H/F start... machine worked exactly like it should. Now all I get is H/F. But I can change the amp/output settings... and I can light up with the machine using the pedal like a torch finger switch, with no amp control..Last edited by DemonSpeeder; 10-03-2012 at 08:09 PM.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
GMT+8, 2026-1-2 12:06 , Processed in 0.110798 second(s), 18 queries .
