what tig torch do i need?
发表于 2021-8-31 22:13:13 | 显示全部楼层 |阅读模式
i have a lincoln square wave 255. panel goes up to 316 amps. right now i have a water cooled wp-18 water cooled torch, and a wp-20 air cooled torch that came with it. I dont really like the 18, as its bug and bulky. im used to using a wp-20 water cooled at work on our syncrowave 350 lx. ive set the lx on 300 amps/ac and used the 20. now on thicker stuff i break out the larger torch at work when needed, rarely. ill prob sell the wp-18, and the air cooled torch to buy a smaller bidies water cooled torch.question is i want a smaller torch than the 18. is the 20 ok for my lincoln sw 255? if not what torch can i get for it that has a small body like the wp-20? thanks a lot Joe
Reply:the 20 is a water cooled torch, the wp9 is the aircooled version of a wp20  (same consumables)   most wp20' are rated for 250 amps or less.   then u go to the wp18 which has a 350amp rating on average.   however lots of people run the torches above that.   If you are not maxing out your machine constantly I would think a WP 20 is fine for your machineTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I agree with southpaw, yet I also know you will be worried about the power cable.  Buy a CK fuse block and run your torch through it.  It will protect your power cable and if it blows the replacement fuses are about 2.50.http://www.ckworldwide.com/fuse_block.htm
Reply:ok, the wp-20. now how hard is it to install the fuse? seems easy, looks like it may be a pain....lemme know. thanks, Joe
Reply:The fuse has screws at both ends and only fits one way, Easier than removing your cable cover and replacing your power cable.
GMT+8, 2026-1-2 12:03 , Processed in 0.109856 second(s), 18 queries .
