End Mills
发表于 2021-8-31 22:13:13 | 显示全部楼层 |阅读模式
Anyone have a sugestion on good low priced end mills. I have used Morse end mills and they hold up well but I would like something a little cheaper if possible. I have a set from grizzly that are decent but you can tell they are low end.Making as much progress as a one legged duck in the middle of a pond, just going in circles.
Reply:i've bought tool holders and collets from shars.com, they were imports and they were actually pretty good quality for the price..  I wouldnt be scared to try their endmills.. something you might consider is going to carbide, yes they cost more, but they also last much longer..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Honestly watch for a "endmill lot" on ebay and get the whole lot. You get endmills and cutters you wouldn't normally just buy and they will get you out of a pinch sometime. I bought both a endmill lot and HSS lot for the lathe. I am very happy I did, very interesting the different HSS there are and nifty endmills that I wouldn't otherwise have if I bought new, separately.
Reply:Thanks for the info guys. Will check into the lots on Ebay.Making as much progress as a one legged duck in the middle of a pond, just going in circles.
Reply:I just bought end mill lot from ebay. 50 lbs worth. Most of them brand new for 70 bucks. There has to be worth of 1k cutters. Search toolyouup on ebay. He has tons of them.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Thanks, I will look him up.Making as much progress as a one legged duck in the middle of a pond, just going in circles.
GMT+8, 2026-1-2 10:12 , Processed in 0.175402 second(s), 18 queries .
