Hobart .023 drive roll same as Miller part #?
发表于 2021-8-31 22:13:13 | 显示全部楼层 |阅读模式
Is the Miller drive roll the same as the Hobart with the same part number:   237 338 ?Lincoln AC/DC 225/125 and WP17. 75A AC is for pipe thawing!HH 140 - new addtion 9/2012.I didn't agree, but hoped for Hope and Change.I got change for myself and my family: for the worse.This is the reality of: Barackalypse Now. Again.
Reply:Not that it answers your question, but both companies are owned by Illinois Tool Works, and -- while the welders are manufactured in separate facilities -- there are some Miller components common to both.Jack OlsenMy garage website
Reply:What Jack said and if it's your Handler 140 that's the reason for you're asking, its manual calls for PN 202 925 for the .024/.030-.035 drive roll rather than the 237 338.  Not sure what the differences would be.Nevertheless, both are listed on miller4less:http://miller4less.com/advanced_sear...22&search.y=15http://miller4less.com/advanced_sear...19&search.y=14MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yes it is for th HH 140, but my manual shows this: Attached ImagesLincoln AC/DC 225/125 and WP17. 75A AC is for pipe thawing!HH 140 - new addtion 9/2012.I didn't agree, but hoped for Hope and Change.I got change for myself and my family: for the worse.This is the reality of: Barackalypse Now. Again.
Reply:OK.  I was looking at earlier manual# 925 revision F.Is 925H correct for your unit SN?Last edited by duaneb55; 10-06-2012 at 06:08 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55OK.  I was looking at earlier manual# 925 revision F.Is 925H correct for your unit SN?
Reply:Then I'd say you're good to go with the 237338.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-2 12:04 , Processed in 0.083431 second(s), 18 queries .
