Pirahna II Tungsten Grinder
发表于 2021-8-31 22:13:10 | 显示全部楼层 |阅读模式
Got some bills to pay and I don't do much GMAW anymore. Straight off of the site:Piranha II Tungsten Grinder. This grinder is ideal for general shop usage. Ideal for 1-3 welders. It includes a universal collet, which will grind from .040-3/32. This unit is fully enclosed and will contain excess tungsten dust.(12 x 8 x 8 - 14 lbs)-Easy set-up, optimal consistency and near-perfect repeatability.-Compact, durable and solid design with no vibration.-Longitudinal 20 RA grinding for maximum arc starting, arc stability, electrode life and weld penetration.-Universal collet arm for 3 electrode sizes - 040" (1.0mm), 1/16" (1.6mm), 3/32" (2.4mm) - with no equipment changes.-Included angle scale for angles from 10º - 60º Precision tip flat gauge & depth adjustment stop ensures exact tungsten points every time - enabling consistent, repeatable arc performance and welding output.-Containment baffle to keep dust inside the grinder housing, for safety and easy disposal.-Electrode notching station for simple cut-off.-Double-sided grinding wheel for maximum wheel life and value.The unit is completely operational and the wheel is in good condition. Retail price is 725$, so I'm looking to sell this for 500$ with free shipping anywhere in the 48 continental. Paypal is [email protected]. Thanks for looking!
Reply:Pirahnas do work nicely, and vacuum dust collectors are available too.
Reply:Bump, no reasonable offer will be refused!
Reply:Would offer to pay $350.00 for your grinder
GMT+8, 2026-1-2 10:13 , Processed in 0.113127 second(s), 18 queries .
