$300 a good price for a Lincoln 140?
发表于 2021-8-31 22:13:08 | 显示全部楼层 |阅读模式
Someone taking my welding class is selling a Lincoln 110v mig welder. He says it takes the bottle and was purchased recently... he also says it's got about 20 hours on it.He's asking $300, he thinks it's a 140 but I'm going to check it out before I buy it.Is $300 for a 140 in this condition a good buy? (I'd probably try to get it for $250)
Reply:It sounds like a fair price. $250.00 is better though. With .030 or .035 flux cored wire you can do a lot of stuff with that little critter as long as you stay with 3/16" or thinner steel.StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:I would like to use it for auto body restoration, and small shop projects and repairs. Also exhaust work.
Reply:call him an get it...idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:So I guess it's actually a 135C instead of a 140... is it still worth it?I can go get it now if I want, I just can't find much info on this welder online.
Reply:sp 135c or a weld pak? That is the older model welder. Still a good welder but check it out completely. May need a new liner in the miggun. Make sure it will weld and the gun is good. the lincoln gun has a bad habit of coming apart at  the welder end. If the gun is pulled on a lot.The powermig / weldpak 140 is the current model.  The C models have continuous adjustment of the weld voltage The T models have a 4 position switch.
GMT+8, 2026-1-2 10:13 , Processed in 0.100445 second(s), 18 queries .
