What am I dealing with here
发表于 2021-8-31 22:13:05 | 显示全部楼层 |阅读模式
Gate broke off the hinges so I thought I'd clean it up a little bit and weld it back  without the huge pile of birdsh** on it and now I'm thinking I should of left the pile so I would have something for it to stick to. I'm guessing it's castLast edited by Tmtbob; 03-08-2016 at 08:26 PM.
Reply:Will a magnet stick to the ring? Since I see some rust, I am guessing the ring is a cast iron piece, brazing would be the easiest route.
Reply:That looks like 3/4 '' pipe on upright. I would cut that off and weld new 3/4 '' pipe on upright . Cut ring off and add 3/4'' pipe to it too. Now you'll have like a 3/4'' hinge, get a piece of 3/4'' rod or round to use for pin. You can stagger the pipe so the gate pipe rest on the upright on bottom.
Reply:Originally Posted by BD1That looks like 3/4 '' pipe on upright. I would cut that off and weld new 3/4 '' pipe on upright . Cut ring off and add 3/4'' pipe to it too. Now you'll have like a 3/4'' hinge, get a piece of 3/4'' rod or round to use for pin. You can stagger the pipe so the gate pipe rest on the upright on bottom.
GMT+8, 2026-1-2 12:03 , Processed in 0.114595 second(s), 18 queries .
