Miller 140 autoset question
发表于 2021-8-31 22:13:05 | 显示全部楼层 |阅读模式
I have a miller 140 autoset that I use for fluxcore only. I have not used it for several months, and when I went to use it today the wire would not feed. I opened the side door, and pulled the trigger, and the roller was not turning, so I took the roller off, and the roller shaft will not turn. Any ideas?
Reply:Does yours have a switch for a spool gun? Can't remember, but if so that could be the problem.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
GMT+8, 2026-1-2 10:13 , Processed in 0.096735 second(s), 18 queries .
