tig dinse connector
发表于 2021-8-31 22:13:03 | 显示全部楼层 |阅读模式
has anyone found or built a 5/8 dinse connector? everything in heavy industry is 5/8 but it seems all tig connectors go to is 1/2? like thishttp://www.ebay.com/itm/WP-26-SR-26-...item5d2c84dd47http://www.ebay.com/itm/CK-USAWeld-Q...item4d27717842 but with a 5/8 pin I don't want to have to change out the lug every time I go from stick to tig to air arc
Reply:Originally Posted by joshkolteshas anyone found or built a 5/8 dinse connector? everything in heavy industry is 5/8 but it seems all tig connectors go to is 1/2? like thishttp://www.ebay.com/itm/WP-26-SR-26-...item5d2c84dd47http://www.ebay.com/itm/CK-USAWeld-Q...item4d27717842 but with a 5/8 pin I don't want to have to change out the lug every time I go from stick to tig to air arc
Reply:not sure? im talking about the male pin on the dinse being 5/8
Reply:They make a 5/8" dinse?What machine do they fit?Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:yeah a #2 looks about right
Reply:Is this the style?Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Yes the same as the #2 but for a water cooled tig
Reply:I guess I still have a couple options, I could find a 7/8 x 14 lh starting and bottom tap and try to make that workOrBuy one of those rectangular lug blocks then mount the dinse on a little pig tail off it
Reply:Originally Posted by joshkoltes Buy one of those rectangular lug blocks then mount the dinse on a little pig tail off it
Reply:Will this work? https://www.arc-zone.com/index.php?m...dtd2aft4hk6l52GlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:no I emailed ck today a few times and they said the highest they went was 1/2, I know it dosnt list the pin size there but it is a ck
Reply:Your problem may be you keep referring to this as a Dinse connector. It's NOT. It's a Tweeco connector and it may look similar but they are not the same. A Dinse connector has a small lug on the side of the body while a Tweeco connector is split down the center and has a flat like in your pictures.This is like why you won't find any one able to supply parts for a Taurus made by Chevy..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:hey thanks ill try that, all though I can for see that my clerical error will not affect my search.
Reply:Lincolns Tweeco style tig connector for air cooled torches.http://www.lincolnelectric.com/en-us...olnElectric%29This page shows CK's Tweeco style tig connector (SLWHAT-T) used for both water cooled and air cooled tig torches.http://www.ckworldwide.com/hookup_extension_kits.htm.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:maby this would work but the listing reads the reverse of the pichttps://www.arc-zone.com/index.php?m...oducts_id=2891
Reply:nopehttp://www.lencocanada.com/pdf_300-02.html
Reply:Can't you get a tweco end for your tig torch?Here...https://www.arc-zone.com/index.php?m...oducts_id=9932Last edited by Boostinjdm; 12-09-2014 at 02:33 AM.My name's not Jim....
Reply:Hey thanks I bought that last one now I guess we can see what shows up!
Reply:Dang I should have read that more closely! The tweeko lug is correct but I ordered the wrong thread on the back oops, well I have two more coming hopefully I ordered correctly this time
GMT+8, 2026-1-2 10:12 , Processed in 0.144059 second(s), 18 queries .
