查看: 13|回复: 0
Tig stainless steel weld test
发表于 2021-8-31 22:13:00 | 显示全部楼层 |阅读模式
I have a weld test tomorrow for mig and tig stainless socket joint welds and I've never done stainless, just carbon steel. Can anyone please give me the main differences. Thanks!
Reply:Main difference? One is shiny the other isn't ......sorry, couldn't help myself
Reply:Originally Posted by Bosco99Main difference? One is shiny the other isn't ......sorry, couldn't help myself
Reply:Well thanks *******. I know that but I'm talking about heat settings, machine setup, and the actual welding.
Reply:Stainless welds similar to mild, but heat input/control is of much greater importance. You fail to mention thickness of the material and other important pieces of information that would really illicit a meaningful answer.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Ah, the seven star response to humour. Good luck on your test. Hope you get the info you need.
Reply:Originally Posted by Robert HallStainless welds similar to mild, but heat input/control is of much greater importance. You fail to mention thickness of the material and other important pieces of information that would really illicit a meaningful answer.
Reply:Back purge and watch the heat input.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
GMT+8, 2026-1-2 12:02 , Processed in 0.217158 second(s), 18 queries .
