mig welding 30mm to 40mm
发表于 2021-8-31 22:13:00 | 显示全部楼层 |阅读模式
got some weldeing to do to make a jig tomorrow 500mm across and  30mm thick to a 40mm thick platei dont know how many passes it should be with the mig. im guessing 1 route and a capping is no good, how many welds will i need to do and how big should the lrg lengths bedoes any body know or have a better guess than me ?regards
Reply:Leg lengths, in general, are equal to the thinner of the two pieces.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:thats a few runs ill need to put down then. thanks for the reply.
Reply:OH! I forgot, this is the dot.  Seemed an odd question from "slob"30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:how can i change my name   the confusion happened last time i posted also
Reply:Will you be dot-slob or slob-dot? lolDave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2026-1-2 10:13 , Processed in 0.113079 second(s), 18 queries .
