Another Cnc Plasma Table build
发表于 2021-8-31 22:12:59 | 显示全部楼层 |阅读模式
A few years back I started building a CNC plasma table. After I started I saw someone's design that I liked much better. So I decided to try and copy his design. I started this a little of a year ago, and since then I had a computer crash. I will get pics of my beads for you the next time I go out to the shop. Here are some of the pics. The table will cut a 5'x10' sheet. I plan on having a plate marker and a 4th axis rotary cutter.
Reply:After welding the top warped due to the weld in the center. So I headed it back up and applied a little pressure to straighten it out.
Reply:i don't know why the posts rotates my pics to the left. I have tried rotating them then uploading, but that doesn't help. I type all my comments and then attach a pic  at the bottom and if puts the picture in the middle of my text.
Reply:Here are parts I drew and had machined.
Reply:I had the water pan bent on a CNC brake so they would come out right. I didn't think I could get them as accurate on my brake. However, they needed modifications because they didn't follow the drawing. So I fixed them on my brake.
Reply:The Y axis and the X axis will both have 3.75 gear reduction.
Reply:Great tools in the background by the way. It is looking awesome. That's some huge project.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Originally Posted by lik2waterskii don't know why the posts rotates my pics to the left. I have tried rotating them then uploading, but that doesn't help. I type all my comments and then attach a pic  at the bottom and if puts the picture in the middle of my text.
Reply:Or when you rotate the pics, save them. I can rotate pics on my phone but if i don't save them it only changes the way they display on my phone...GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by surfsideGreat tools in the background by the way. It is looking awesome. That's some huge project.
Reply:Attached Images
Reply:Nice project. I am at the tail end of my build. I have been on it over a year. I also have to get some warpage out of my table too. I need to do that.T.J.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Originally Posted by TJSNice project. I am at the tail end of my build. I have been on it over a year. I also have to get some warpage out of my table too. I need to do that.T.J.
Reply:TJS I found your build thread. Nice build!
GMT+8, 2026-1-2 10:13 , Processed in 0.111606 second(s), 18 queries .
