Anyone make a welding table that will "nest" in over your welder?
发表于 2021-8-31 22:12:56 | 显示全部楼层 |阅读模式
I have a small garage and looking to make a table in the near future that will roll right over top my Syncro 200 for storage.  (Very similar to pushing a chair in and under a table/desk.)  This would mean obviously that one "end" would have to be open so that it would not hit the welder when "nesting" the two.  I envision a small table, maybe 3x4ft.  If you made one like this, can you post a pic or point me to a thread?  Thanks!KRS
Reply:Something like this ?
Reply:Not mine, but simple enough."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Those look great.  I am thinking more like the bottom one but with casters.  Thanks guys!
Reply:Here is what I did, could be modified to fit your need pretty easySent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:I tossed around the idea of making a tall cart for my plasma that could straddle my mig. Maybe someday.Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:I'm assuming you want your welder to be movable about your garage so why not just build a cart that can roll under said table? If not then build a table with a shelf for your welder and have casters on the table.
Reply:Originally Posted by 808stateI'm assuming you want your welder to be movable about your garage so why not just build a cart that can roll under said table? If not then build a table with a shelf for your welder and have casters on the table.
Reply:This one is beautiful.  3/4" plate tapped and Blanchard ground.  Build thread: http://www.practicalmachinist.com/vb...thread-194945/"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Mine:   2'x4'it roll over my part washer
Reply:Originally Posted by OldendumThis one is beautiful.  3/4" plate tapped and Blanchard ground.  Build thread: http://www.practicalmachinist.com/vb...thread-194945/
Reply:Wow, that thing is to pretty to weld on!
Reply:Originally Posted by GumneckThere are five leaves on that guys floor....appalling!Nice table though.
Reply:I made a table at work with the same idea in mind. Instead of using horizontal cross members, I just used large gussets to support the legs all the way around.  That table doesn't get moved though.  I will try to take pics later.
Reply:Originally Posted by huntall6I made a table at work with the same idea in mind. Instead of using horizontal cross members, I just used large gussets to support the legs all the way around.  That table doesn't get moved though.  I will try to take pics later.
Reply:Originally Posted by KRS62Wow, that thing is to pretty to weld on!
Reply:That's a solid looking table Camoboss!
Reply:No. I think nesting my PrecisionTig 275 would be really tough. It has the undercarriage and water cooler drawer plus it is on wheels with a dual tank setup.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2026-1-2 10:12 , Processed in 0.074085 second(s), 18 queries .
