Another Truck Bed
发表于 2021-8-31 22:12:56 | 显示全部楼层 |阅读模式
Nothing too wild pretty simple will end up with a 2" angle lip around the frame with a floor of wooden 2x6's inlaid. Attached Images
Reply:Are you just using the truck to tack it up, or are you mounting it with some shock absorbing material?
Reply:I'm going to lift it off the frame after it's all tacked up.
GMT+8, 2026-1-2 12:04 , Processed in 0.100642 second(s), 18 queries .
