So I want to build a trailer
发表于 2021-8-31 22:12:55 | 显示全部楼层 |阅读模式
Alright I want to build a trailer. I'm looking to build a 7.5x18ft flat deck trailer. Mainly for hauling my antique John deere tractor and anything I can put on it.  I want to use 2 5000 lbs axles.  But I'd like to see some of your tailer builds that are similar to my idea.Miller Bobcat 255Hobart 190 and spoolgunLincoln AC 225Lincoln LN-25Rock and Roll hoochie coo
Reply:Prepare your thick skin!
Reply:You better repent now, bobcat.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Lol oh boyMiller Bobcat 255Hobart 190 and spoolgunLincoln AC 225Lincoln LN-25Rock and Roll hoochie coo
Reply:Checkout FarmerSamm’s trailer build http://weldingweb.com/vbb/showthread.php...ler&highlight=Everlast PowerPro 256, Everlast W300 Cooler, Everlast Cart 250Millermatic 211, Spoolgun 100, Miller HD CartJackson W60 Truesight Digital Auto Darkening, Victor 315 Torch sitting on a Harper 830-86 cart
Reply:You can't build a trailer untill you get a 120 volt mig welder with flux core wirewww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Originally Posted by mechanic416You can't build a trailer untill you get a 120 volt mig welder with flux core wire
Reply:Originally Posted by AKweldshopWith co2 for cooling gas...
Reply:Getting the recliner ready. Attached Images30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:In all seriousness though - for a "big" trailer why not buy pre made plans - last I saw them they were about $45.It would be money well spent and save tremendous time But, home built trailers generally end up more expensive then buying one.Don't get me wrong, I've done it too, but I also buy used ones cheap and work them to death - modifying on the way.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:This oughta be goodMiller Spoolmate 200 w/t S-52 WirefeederMM 211'09 Miller Trailblazer 302
Reply:Originally Posted by AKweldshopYou better repent now, bobcat.
Reply:Originally Posted by Ian DuffinThis oughta be good
Reply:Ok I will risk it. I agree with Minnesota Dave, buy the plans or buy a nice trailer. I think that I spent as much as what it would have cost to buy one. But I do have one heavy trailer. So here is a picture. The trailer was built about 1996 or so picture was last summer. I think it needs a new coat of paint.
Reply:I forgot to mention it the deck tilts for easy loading.
Reply:Originally Posted by MinnesotaDaveHa! This'll do it - says HD right on it for "Heavy Duty"
Reply:Originally Posted by KMcCurdyThat lincoln won't do it. You need that 90 amp harbor freight machine. ��
Reply:Ok, I'll assume your not just looking to have some fun and post some pics of a few examples of my work. If your really looking for advice on what to build I would need more info on what you want to do with the trailer and what tractor you want to haul. The is a lot of difference between an MT,  a B, and a 4020.Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Take that piece of crap I built last Winter, add 1" to the main frame rail, and you have a 10,000gvwr trailer (honestly)."Any day above ground is a good day"http://www.farmersamm.com/
Reply:A few moreYeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Can you pass a bend test? Originally Posted by MinnesotaDaveIn all seriousness though - for a "big" trailer why not buy pre made plans - last I saw them they were about $45.
Reply:Originally Posted by mad welder 4They don't work so well when you are buying what ever the scrap yard has for steal.
Reply:Don't buy the plans, just find a trailer you like and copy it. Also, don't build an 18', go ahead and build a 20'. You won't regret it.
Reply:Originally Posted by welderjOk, I'll assume your not just looking to have some fun and post some pics of a few examples of my work. If your really looking for advice on what to build I would need more info on what you want to do with the trailer and what tractor you want to haul. The is a lot of difference between an MT,  a B, and a 4020.Originally Posted by mechanic416You can't build a trailer untill you get a 120 volt mig welder with flux core wire
Reply:Originally Posted by jamesyarbroughAnd u have to use old bed frames!
Reply:Originally Posted by shaynoakthose are some awesome trailers!
Reply:Hey guys sorry for the delay in between posts.  I have a John deere 60 and I do tractor pulling ans just need a trailer suitable for that.  I work for a large Construction company and I can buy my steel from them if I need to.  I'm a welder for Skanska USA at the moment.   I don't really need a tilt deck but I'm looking to haul my tractor which weights 6500lbsMiller Bobcat 255Hobart 190 and spoolgunLincoln AC 225Lincoln LN-25Rock and Roll hoochie coo
Reply:Are you narrow enough with that to get in a car hauler type? They are cheaper to build, and easier to load since they are low. Depending on what you use for tires you can get at least 80" between the rails and as much as 82 or 83" and be legal. I can show you several options for designs that work real well. Would really save you some money and time. But if you want or need a flat deck, then at least go 8' 6" wide for resale value.Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Thanks welderj.  Pm me the designs if you want.Miller Bobcat 255Hobart 190 and spoolgunLincoln AC 225Lincoln LN-25Rock and Roll hoochie coo
Reply:Engineered Blueprints are available from Northern tool for between $29. for bumper pull to $39 for goose neck,Have complete bill of material and welding procedure.  I bought a hole stack of different  plans from them  and keep them handy. Then at least you can sue someone other than FarmersammLast edited by gxbxc; 01-18-2015 at 11:26 PM.
Reply:"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersamm
Reply:Originally Posted by gxbxcEngineered Blueprints are available from Northern tool
Reply:Originally Posted by welderjMust be beer night fer yer little dude there Samm, looks like he fell off his stool
Reply:Okay Sam put down the beer and take a step away from the welder! What is that you are building anyway did you say? Is it a bed frame ? And before I forget what is that nice looking little crawler ?gxbxc. Oh and I didn't mean to throw you under the Lawyer bus ,but you are so helpful to the guys in need.Last edited by gxbxc; 01-19-2015 at 09:26 PM.
Reply:Originally Posted by farmersammMy dear Sir, tonight is indeed beer nite.  Every Monday, as long as the Earth spins, and the Sun comes up in the East  It's something you can set your watch by.I believe if I was capable of this sober, (I guess anyways) , I believe I'd spend the rest of my life drunk as a skunk....couldn't be any worse I'd imagineTake care my friend
Reply:Originally Posted by gxbxcOkay Sam put down the beer and take a step away from the welder! What is that you are building anyway did you say? Is it a bed frame ? And before I forget what is that nice looking little crawler ?gxbxc. Oh and I didn't mean to throw you under the Lawyer bus ,but you are so helpful to the guys in need.
GMT+8, 2026-1-2 10:13 , Processed in 0.160584 second(s), 18 queries .
