Industrial grade rolling welding shop for sale or trade for diesel pickup $15,500
发表于 2021-8-31 15:01:53 | 显示全部楼层 |阅读模式
I have a welding trailer built on a 3/4 ton GMC chassis.  It is a rolling weld shop.It has a 225 amp generator/welder with a new battery and carburetor that operates on both CC and CV mode.  It comes with a high frequency unit, air cooled tig torch with finger control, a wire feeder, oxy-acetelyne welding and cutting torches with a variety of tips and large full owner owned  oxygen and acetylene tanks.In addition the trailer has a fold down tailgate that doubles as a work bench with a 6" vise mounted on a heavy plate for situations that requires a pounding surface.Included are two full large owner owned argon and argon/co2 mix for tig and mig welding and flow meter.Included also is a drill press and removable bench grinder that can be placed in two different locations on the trailer by inserting into a pair of  receivers.The trailer has a 175psi gas drive electric start air compressor with an air splitter/manifold for multiple tools as well as a 25ft air hose on a reel. A tool box on the trailer tongue contains a new battery, hydraulic jack and lug wrench for replacing tires.  The trailer has new tires and a spare mounted under the bed with a tire winch that can raise and lower the spare. The trailer has a hinged fold down work table with level adjustable feet to accommodate uneven surfaces. There are four shelves built in to the trailer to hold a variety of tools and the wire feeder. I included a series of clamps, hammers, come along, bars and layout tools in addition to a pair of 5 gallon Jerry cans for spare gas.Finally a set of welding gloves, welding hood and leather jacket is included.  It is covered with a heavy vinyl tarp to protect it from the environment.This is a total turn key system ready for you to hit the ground running.  call Tony at #602 #920 #3784
Reply:Looks great 👍. Most welders make there owners and add one piece at time.Your trailer looks great. Dave
Reply:That is a great little setup!Best of luck on the sale.
GMT+8, 2025-12-18 18:25 , Processed in 0.091042 second(s), 18 queries .
