Reddish-purple coated drill bits - Makita
发表于 2021-8-31 22:12:53 | 显示全部楼层 |阅读模式
Today I bought some tools from an elderly couple, including a set of drill bits. The bits don't all match, but some of them have a reddish-purple coating on them and are marked MAKITA HS USA. I'd never seen purple drill bits before, are they anything special or just junk?Lincoln 175HD
Reply:Guessing it's just a heat treatment on high speed steel bitsMiller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:a friend of mine had some makita bits like that and I found them to be pretty good.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Those are the Designer Series, colored to match the curtains.  Keeps the SWMBO pleased.  On how many other forums did you post this same inquiry? That isn't a problem, it's just that when I ran a search on "Makita HS drill bits" the same posting popped up on at least three other forums!Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Yep, I posted it on a few forums because I'd never seen drill bits that color before. Google managed to index them the same night, surprised me.Lincoln 175HD
Reply:They may have been marketed as Cobalt bits, In reality they are probably a HSS bit with a "cobalt" surface coating.
Reply:I've got a few of those. they are pretty good bits, not sure of the composition, but they seem to be as durable as a good cobalt bit. Purple coating doesn't seem to do much other than make them stand out on the rack among the other bits.Ian TannerKawasaki KX450 and many other fine tools
GMT+8, 2026-1-2 12:03 , Processed in 0.112676 second(s), 18 queries .
