The Daddy of all Squares
发表于 2021-8-31 22:12:51 | 显示全部楼层 |阅读模式
Anyone got a Big square to equal this??Now thats one serious big square its about 3ft tall  Very handy for sqaring up frames, and Structual Steel I've put a tin of Tip Dip next to it so you can judge just how big this daddy is Anyone got one bigger??
Reply:Do you have to use the yellow plate clamp and hoist  to move it ???
Reply:drywall T square count ? 4feet long.The square I have is 1 ft by ~30" all a single piece of 1/8" plate that was my grandfathers. I cannot read the ruler on it at all anymore, but it still gets things square!miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:At work, we have some that are 13' long. Use to check the squareness of carpet patterns coming off the coater on 12' wide carpet.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Odd was of doing it.  Over here we square to the web.  On big things we use 3,4,5 or bubble levels or even digital levels..
GMT+8, 2026-1-2 10:40 , Processed in 0.107813 second(s), 18 queries .
