F.s brand new condition - miller xmt 350
发表于 2021-8-31 22:12:49 | 显示全部楼层 |阅读模式
Miller Technology Exclusives:Auto-Line™ Power Management Technology puts you in control of the primary power. Now, primary power managment begins at the plug and ends in your wallet.Lower primary amperage drawPermits more welding machines without boosting incoming service.Better weld Quality, uninterrupted productionRock steady arc even during fluctuations in primary power.Universal location flexibility: Plug in anywhereAccepts any type of primary power — 208-575 VAC, single- or three phase, 50 or 60 Hz.Exceptional electrical efficiencyHelps the XMT 350 pay for itself through lower utility bills and rebates.Miller's Auto-Line circuit internally boosts primary power to a higher voltage. After being regulated, this power then becomes the source voltage for the actual inverter section of the power source.http://www.millerwelds.com/products/...mt-350mpa.htmlNEW THIS IS $4666.00asking $3350.00located in ontario canada Attached Images
Reply:So is this an MPA, CC/CV, or VS?  Your link goes to an MPA, but your price suggests a CC/CV (which sell brand new from Cyberweld for $3700).  How old is it?  Can you give us any info that isn't from Miller's website?Your pic doesn't work, btw.
Reply:its the cc/cv only used twice and it a month and a half old.make an offer if interested.
GMT+8, 2026-1-2 10:40 , Processed in 0.105355 second(s), 18 queries .
