Hey guys and gals, I bought a new precision tig 225 in august and am wondering about the ability of adding an aftermarket water cooled torch to it. I already have a weldcraft watercooled torch, does lincoln make and adapter for it. Or does someone make an aftermarket adapter? been looking just haven't found anything yet. Thanks!!!
Reply:My Precision Tig 185 came with the Lincoln Tig Mate water cooled torch kit and another Esab water cooled torch. They both have a standard adapter for the machine and the water lines just run to the cooler. You should be able to buy an off the self twist plug for your torch. I hope this helps... If you need more information on it let me know...
Reply:If you have a part number that would be great!!! Thanks!
Reply:It is Lincoln Twist Mate K1622-4. That is is the number from my 185 manual. It should be the same for yours, but you should double check it... |
