ANYONE Have a pic of the crankshaft (taper end) used on a ranger 8 welder, the welder was built in 99, dont have a code, Iam lookin at a new engine for sale that has a good pic of the tapered crank but thats all i got, I need a new engine for the welder , will be sold today, Thanks Eric
Reply:Sorry I didn't see this earlier. I was 40,000' in the air for 16+ hours.Lincoln used the tappered crank code# 45BG with details shown in the .pdf file below.Onan Crankshaft Descriptions.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks for responding dewane,..The engine ,.A, brand spankin new in the box onan p 218, sold for 366.00, i didnt dare sell out for a maybe fit , so I folded ,..Thanks,. Eric
Reply:OUCH! That would have been worth picking up to resell if you didn't use it yourself. Could have changed out the crank if necessary too but. . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:my thoughts exactally,...moneys tite here,......wish IIII could have bid a bit longer,... BUT Reality is what it is,....Ive been busy gettin tucked in for the winter here in michigan,.. hope to get the weldanpower on the wash rack soon and spruse the old girl up,.for sum 7018 puddles,..Just hopin all I need is that $5,99 part, Thanks again for all your contrubutions to this great site,.....Eric
Reply:Do you have a hole in your block? Is your crank bad? If your oil pan is still good and your block is good Id rebuild it. Im thinking the mini blocks are high, short blocks are really high, and the long block is in outer space. I agree on the resale of the onan. I know some of the carb kits for them are around 150, you could get 200 just for the carb! heres mine. Attached Images |
