Lincoln AC 225 welder stopped working
发表于 2021-8-31 22:12:45 | 显示全部楼层 |阅读模式
I had some kids using this welder and I think they might have stuck the rod to the work and let it run too long in that state.  Anyway, for a while it would run for a short time then it would quit working.  It was difficult to stabilize the arc.  Now it's completely dead.  You can't strike an arc at all.  Is there something I can check, like maybe an internal fuse or something?  Any help would be appreciated.This is one of those umbiquitous red, tombstone-looking AC stick welders.  It's not very old.  Several years maybe, but it's seen a lot of use.
Reply:Unplug the welder and pull the back off. Look and the range switch. You will most likely  find a damaged switch. You will need a large soldering iron or a propane torch to solder in a new switch. Do not cut the wires, cut the little tab then unsolder the wire and move it tot he new switch one at a time. If the switch contacts are good but the shaft is damaged. The shaft is replaceable.
GMT+8, 2026-1-2 10:40 , Processed in 0.104999 second(s), 18 queries .
