Regular maint question for a lincoln Sa-250 Diesel
发表于 2021-8-31 22:12:45 | 显示全部楼层 |阅读模式
Just got a Sa-250 D3.152 diesel I was looking to find some info about what engine oil, filter number, fuel filter number, air filter number and how to reprime the fuel system after changing the fuel filter? Any help would be awesome. Thanks
Reply:I have the same machine. For the filters I go to carquest. Not sure if u have one of them where u are At but u could look up and cross refrence on the web. Oil # 85460. Fuel # 86166. Not sure for the Air. As for the fuel, remove the old and replace. Then use the manual pump, the lever on the pick up pump, to fill the bowl. The only way I know how to bleed the system is to undo the 3 hard lines that go to the injector and crank the engine untill solid fuel spits out of each and all the air is gone. This has worked for me but there may be an easier way
Reply:I use shell rotella t all yr long 15-40. It's what I run in all my diesels. Temp range is 40f-110 degrees   Just my preferance
Reply:Do you have crack the injectors just to change the fuel filter? Also how many quarts of oil does the machine hold? Thanks I really appericate the help.
Reply:I have a sneaking suspicion it's all in the manual, usually available online, or available from your dealerBTW...........if the rings are good...........Rotella by all means, but if it's blowin' down into the crankcase use the Wal Mart cheapo 15-40. Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I have looked through all the manuals I could find on lincolns web site they talk about the machine but when it comes to any thing about the engine it says to refer to the engine operators manual. When I looked up the perkins only thing I could find on them is the 4 cylinder 4.1 something perkins. I guess if I can't find it out here I will go by the dealer ship and talk with them.
Reply:You should own an engine manual anyway, but...Filter numbers vary by manufacturer.Oil specs vary by climate, operating conditions, and personal preference.When changing filters, if air is carefully purged from the filter housing(s) and at the two bleed screws on the injection  pump housing you may get by without cracking the lines as FEARSUM described.Good LuckLast edited by denrep; 05-27-2010 at 08:42 AM.
Reply:I belive I got my engine manual at.  Pdfgeni.com. Search Perkins 3.152. As for the fuel filter, u can try to change it without purging after but I haven't had luck with that. These Perkins can be very picky and hard to get started once u get air in the system. If u purge at the injectors u are for sure all the air is out.
Reply:Originally Posted by FEARSUM . . .These Perkins can be very picky and hard to get started once u get air in the system. . . .
Reply:Originally Posted by GmmandanJust got a Sa-250 D3.152 diesel I was looking to find some info about what engine oil, filter number, fuel filter number, air filter number and how to reprime the fuel system after changing the fuel filter? Any help would be awesome. Thanks
Reply:Hi my welders injection pump broke done any body now's where to get one its on a sa250 3d-152 Perkins
Reply:Ok guys, I'll chime in on this one as a regular old ASE part/heavy truck specialist. The filter at Carquest (#85469) is manufactured by WIX. The WIX part number is 51460. Part Number:51460UPC Number:765809514607Principal Application:A-C, Eicher, Hyster, JCB, M-F, Perkins EnginesAll ApplicationsStyle:Spin-On Lube FilterService:LubeType:Full FlowMedia:PaperHeight:5.811Outer Diameter Top: 2.966Outer Diameter Bottom: ClosedThread Size:3/4-16By-Pass Valve Setting-PSI:15-17Anti-Drain Back Valve:YesBeta Ratio:2/20=6/19Burst Pressure-PSI:300Max Flow Rate:7-9 GPMNominal Micron Rating:21Gasket DiametersNumberO.D.I.D.Thk.Attached 2.740 2.370 0.275Thats for the Oil. As for the fuel, Carquest # 86166. is WIX filter 33166Part Number:33166UPC Number:765809331662Principal Application:CAV Fuel Systems - All Major Equipment (10 Micron)All ApplicationsStyle:Cartridge Fuel Metal Canister FilterService:FuelMedia:PaperHeight:2.825Outer Diameter Top: 3.470Outer Diameter Bottom: 3.328Inner Diameter Top: 0.750Inner Diameter Bottom: 0.875Max Flow Rate:6-8 GPMNominal Micron Rating:10Gasket DiametersNumberO.D.I.D.Thk.Packed 3.375 3.125 0.125O-Ring 0.755 0.549 0.103O-Ring 0.379 0.239 0.07015366 3.459 3.159 0.120Anything that conforms to those standards should work. Heres a link for the 51460  http://www.amazon.com/Wix-51460-Spin.../dp/B000CSD49OAnd a link for the 33166http://www.amazon.com/Wix-33166-Cart.../dp/B000C9XZ88And that's it. I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:I'm trying to find the air filter numbers... not helping that I don't have a manual.If someone comes up with a part number from anywhere I could try to find you one.I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:@ BeachboyThere's one on Ebay for a 3cyl D152. http://cgi.ebay.com/ebaymotors/PERKI...#ht_1979wt_995Might wanna double check that though...I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:Jesus not even a thank you ....I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:At Lincoln site entering your code number is the best way to find the manuals for your particular welder.Operators Manualshttp://www.mylincolnelectric.com/Cat...ualsearch.aspxParts Listhttp://www.lincolnelectric.com/produ...e/partsnav.aspWix Filters site is usually easy way to look them up and even if you don't have a Wix dealer nearby most places can cross from a Wix number.  NAPA filters are made by Wix so their numbers are nearly the same.http://www.wixfilters.com/Air Filter   42276     SA250 w / Perkins D3.152 Engine   Fuel Filter   3316653     SA250 w / Perkins D3.152 Engine   Oil Filter   51460     SA250 w / Perkins D3.152 Engine
GMT+8, 2026-1-2 10:39 , Processed in 0.086341 second(s), 18 queries .
